In Creo parametric if I change unit mm to inch in the part file after that if I check that detailing file some view have been distorted, section arrow becomes big and some views are missing.
For us to help you better, can you provide screen shots, attach files?
I did a quick test. I made a part in inches. I just used random numbers.
I created a drawing, showed the dimensions. I didn't try to make a good drawing,
I then went back to the model, changed the part from inches to mm.
Initially, when I returned to the drawing the views were "small" compared to the original.
I regened the drawing views and all came back as if nothing had changed.
See images.
Hi Stephen,
Thank you for the quick response on this
For small drawings, it is changing perfectly without any issues but if you have 3 sheets and a detailing file containing 100 annotations and in a sheet, some 4 ya 5 detailed views are there that time some views are distorted so this is how can I resolve.
Have you tried closing out of the drawing, clearing memory and then reopening the drawing?
