Hi everyone,
I have a problem in a P&ID diagram in Creo Schematics. When I sometimes select an inline-component from the catalog explorer is does not intersect with the lines already drawn in my P&ID.
I assume it is a shortkey or something small which causes this.
Can you help me out?
greetings, Koen
I assume you mean that you are trying to place a component into an existing fiber and it will not allow you.
If this is the case then you need to check the following:
Point 3 is the one that catches the most people out
thanks
Jim
