inserted table height
TracyWillis
Does anyone know how to control the default row height of a table that is inserted from file? The table drops into the drawing with a row height of .098 inch. I know how to change it after it is inserted. I would like to set the defaulta bit higher so I don’t have to change it every time. I’ve tried changing the height in the file before inserting it but the csv won’t hold the formatting.
Any suggestions?
tw
Thanks to Christopher, Daniel, and Matt:
The solution = Once the table is formatted correctly save it as a ( .tbl ) file. It will maintain all of the formatting of the table and it eliminates having to remove the extra lines created with using the csv file.
thnaks again
tw
