license error
MA_14160711
license error
getting invalid file or format while uploading the license file. tried saving it as ".txt" format but still doesn't works.
Possible solutions for "Invalid file or format" status under License Summary while installing Creo: https://www.ptc.com/en/support/creo-admin-troubleshooter/other-symptoms/invalid-file-format
Hi @MA_14160711
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  1. Are you uploading the file through the correct Windchill License Management utility or command-line tool?
  2. Have you verified that the license file matches your Windchill version and CPS level?
  3. Are there any error logs or messages beyond “invalid file or format” that could give more detail?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill / Creo / Thingworx, Kepware, Navigate looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
1.] What license type do you use? Commercial? or Student?
2.] Upload your license file.
3.] Upload ip.txt file generated by following command executed in Command prompt window.
ipconfig /all > ip.txt
Martin Hanák
