My Dell Precision workstation has a Quadro RTX5000 I spoke to an Industrial designer friend at Dell before purchasing this laptop and he said never skimp on a video card. 384 resolution on a laptop. So I was thinking and after using it for the past few years of a few enhancements that might be noted for future releases of Creo. I thought I would bounce this one by the folks on the forum.
So many probably don't know that if you draw a line in sketcher that you can change the linetype *ptc calls incorrectly a font .... or change color. I want to also change the line thickness and have a few selections or even be able to increment thickness of lines. Maybe a developer would consider an option to have the line weight pull thru surfaces or solids as if the surface or solid had a slider for opacity.
Once Creo 9.0 question: What config.pro setting turns off the menu *always on* in creo 9.0
Bart Brejcha
