How do you change the linestyles of certain views within a drawing in Creo 2.0? As you can see in the image, one piece of the equipment is shown in a phantom linestyle and another piece attached is shown as normally viewed. See below.
You can change the linestyle of certain components within a view, multiple view, or all views.
Thanks Eric for the response. I went through your procedure and that worked. Thanks again!
You're welcome!
