hi
how to change unit to g/cm3
If you edit the material file that specifies the properties for "AlMg" you will find a section that defines the density, which looks something like this
Name = PTC_MASS_DENSITY
Type = Real
Default = 7.20e+3 kg/m^3
Access = Full
As you can see, the units for the value are specified. Change the file you have to the proper units and away you go.
You'll probably have to close Creo then re-open it for the change to be in effect. Just a guess, but always best practice.
Material files (.mtl) are just text files. So you could open the mtl file in a text editor (like notepad or notepad ++) and change
Type = Real
Default = 2.7 tonne/mm^3
Access = Full
to
Type = Real
Default = 2.7 g/cm^3
Access = Full
Alternatively you can add it to your model and then right click on it and go to properties and change it there. This will only change it in that model. If you want to save over the old file you can click save or file-> save as a copy and save it that way.
Hello @ssreevalsan,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
