model_name
ptc-2265543
model_name
How can I find the model_name number of a set of instances, ie model_name:4 etc for use in tables?
2 REPLIES 2
Dale_Rosema
(To:ptc-2265543)
If I understand what you are asking, with the model open. Go to Tools, Family Tables. The instance name is usually the first or second column on the left.
Dale Rosema
WF5/Creo
Thanks for the response, Dale, but I am trying to find the &model_name:XX, were XX is the number that differentiates one family instance from another for Pro/E. I have a drawing table that has common instances for it except maybe for length. When I set up the drawing table, I set up the &model_number for 'PART NUMBER' and &Dxx for 'DIMENSION 'A', were &Dxx is the variable dimension. Where can I find the &model_number or the model_number parameter to add to the family instance table?
Joe
