modelcheck
ptc-1703378
modelcheck
Everyone,
I need MC to give me an error for empty parameters. I can show an error for incorrect value just not them being empty.
PRT_PARAMETERDRESCRIPTION STR EQ ??????????????????????
TIA
Ben
5 REPLIES 5
bfrandsen
6-Contributor
(To:ptc-1703378)
Ben,
PRT_PARAMETER DESCRIPTION STR NEQ NULL might do the job for you.
Bjarne
"Benjamin Givehand" <->
06-05-2008 16:44
Please respond to
To
cc
Subject
[proecad] - modelcheck
Everyone,
PRT_PARAMETER DRESCRIPTION STR EQ ??????????????????????
TIA
Ben
Hi all,
Our ModelCheck files were configured by someone years ago who no longer works at the company.
In trying to understand how they work, I've noticed that there are three .mch check files. There have quite a number of entries (rows), but look to be very similar in regard to their respective settings.
For those using MC, do you have different mch files for checking models at different stages, or do you just use one?
Stefan
Here is a great presentation to help you.
Making ModelCHECK Work for You<">http://portal.ptcuser.org/p/do/sd/sid=1170&type=0>
Can Model Check report if features are not molded to the nominal dimension
specified on the drawing.
An example might be a thru hole that is modeled at .625 and dimensioned
.625 +.010 -.000
Can it be configured to report that a feature was not modeled with the
nominal value in this case .630?
Thanks in advance,
Robert
Does anyone know if ModelCHECK is capable of flagging any non-symmetrically toleranced dimensions on drawings?
