modify conflict options choices
DennisRehmer
To all,
I was wondering if there is a setting, or where the option might be, to turn off certain selections when you go to modify a part that is not checked out, so the user cannot select either of these two.
  • Revise and Check out now
  • Revise and check Out Entire Family
We do not want anyone to be able to revise a part/assembly unless thru the change managment process, which is WindChill in our case. Attached is a screenshot of what I am referring to.
If this is not in the correct location for someone to answer, if it can be shared to who would be able to best respond, feel free to do this.
Thank you,
Dennis J Rehmer
ABB
1 REPLY 1
TomU
(To:DennisRehmer)
Not seeing any screenshot attached.
You can turn off the revise commands in the Creo menus.  Take a look at the config option dm_enable_revise_and_check_out no.
https://www.ptc.com/cn/support/article/CS131936
http://support.ptc.com/help//creo/creo_pma/usascii/index.html#page/whats_new_pma/datamangementHideReview.html
If you want to turn revise off in the Windchill menus, including the embedded browser inside Creo, take a look at standard profiles:
https://support.ptc.com/help/wnc/r12.1.0.0/en/#page/Windchill_Help_Center/profilemgmt/ProfileMgmtInfoPage.html#
