my drawing is showing wrong tolerances
Sandy7
my drawing is showing wrong tolerances please see attachment.
the points are not showing even i have entered decimal value.
please help.
Br,
Sandy
MartinHanak
(To:Sandy7)
I think in your drawing following detail option is set:
display_tol_by_1000 YES
Martin Hanák
13 REPLIES 13
MartinHanak
(To:Sandy7)
Martin Hanák
Sandy7
(To:MartinHanak)
hi @MartinHanak
where can i find this option?
Br,
sandeep C.
Sandy7
(To:MartinHanak)
hi martin,
the value for display_tol_by_1000 is set to NO. see attached.
MartinHanak
(To:Sandy7)
@Sandy7 wrote:
hi martin,
I can check your drawing if you upload it along with the model.
Martin Hanák
StephenW
(To:Sandy7)
Is the tolerances showing wrong in the model also?
If so, also check the model detail properties for that same option display_tol_by_1000 YES
In the model (not drawing), FILE - PREPARE - MODEL PROPERTIES - DETAIL OPTIONS CHANGE  and look for the option there also.
Sandy7
(To:StephenW)
no the value is 'no'
Sandy7
(To:Sandy7)
i have attached the CAD and drawing. could you please check and let me know. in my colleagues system it looks fine see attachment tol.png
StephenW
(To:Sandy7)
I can't open you files but IF this is only on your computer and not on another computer, it is likely a config.pro option
I found a config.pro option with the same name.
display_tol_by_1000
You need to check ALL config files You do this by going to FILE - OPTIONS - CONFIGURATION EDITOR and then select either CURRENT SESSION or ALL OPTIONS.
if you see the option set to yes, you will need to look at each config.pro or config.sup (also shown in that same drop down list) and change that one to NO
Sandy7
(To:StephenW)
but it will going to help in current session only right?
once the creo is restarted, it will show the same problem again.
MartinHanak
(To:Sandy7)
I hope you understand that you have to open config.pro in Notepad and change display_tol_by_1000 value to NO
After finishing this actions Creo will show expected tolerance value.
Martin Hanák
StephenW
(To:Sandy7)
If that is the problem, you can change that setting and save your config.pro.
Ideally you will change it in the file it is incorrectly set. If you don't have write access to that specific config.pro, you should get help from your admin.
Worst case, you can set the option in your local config.pro and save that one. It is the last one to load.
Sandy7
(To:StephenW)
when i restarted creo again and opened again the drawing and checked the display_tol_by_1000 value was set to yes.
as soon as i set it to NO the tolerence value came back to normal 😯
thanks guys. really appreciate it.
