hi,
how to open family table instance in Creo View 3.0. can anyone help.
-- Rai
Andy is correct. Your instance needs to have its own viewable. It does not behave like Creo Parametric where you can open the instance from the family table.
Ravi,
I do not believe that it is possible
Martin Hanak
Are you talking about opening the instance from the pvz of the generic? That case is no. Your instances should have its own pvz file.
