otk_java folder have no library files
SD_9870778
Hello, I have installed Creo 8 and choose to also install the c++ and java toolkit. When the installation is done, when I go to:
 C:\Program Files\PTC\Creo 8.0.1.0\Common Files\otk\otk_java, I dont have the library files, I have only the  otk_java_examples ,which have all the example files.
 But for  the c++ toolkit folder, C:\Program Files\PTC\Creo 8.0.1.0\Common Files\otk\otk_cpp, I have all the library file and code examples..
Did I miss a step for the Java toolkit installation ??
Thank you
0 REPLIES 0
