parameter to drive part material?
DaveClark
2-Explorer
Hello Everyone,
I know that I can assign a material, and the value PTC_MATERIAL_NAME holds the name of that material. However, I was wondering if I can reverse that and use a parameter (such as MATERIAL) with a drop down list, and have its value assign the proper material to the part.
Thanks, and have a great day!
Dave Clark
Sr. CAD Application Engineer
Dukane Corporation
Intelligent Assembly Solutions Division
2900 Dukane Drive
St. Charles, IL 60174
630-797-4922 (Phone)
630-797-4949 (Fax)
[cid:image001.png@01CD97FB.97A830A0][cid:image003.png@01CD97FB.97A830A0]<http: twitter.com=" dukaneias=">[cid:image004.png@01CD97FB.97A830A0]<http: www.youtube.com=" user=" dukaneultrasonics=">">http://usblog.dukane.com[cid:image002.png@01CD97FB.97A830A0]<http: www.facebook.com=" pages=" dukane-intelligent-assembly-solutions=" 3139592...
[cid:image005.jpg@01CD97FB.97A830A0]
This image might make what I'm trying to do a little more clear:
[cid:image001.jpg@01CD9804.8924BDB0]
Using this drop down menu, with a restricted parameter list, I was hoping that I could use this list to assign the material instead of using the Model Properties form.
-Dave
Dave -
We have our most common materials pre-assignedto our start parts, thus allowing us to choose them from the drop down list as you have shown without having to go into the Model Properties. I don't know if that is exactely what you are looking for, but perhaps can get you in the right direction.
Josh
In Reply to Dave Clark:
-Dave
RandyJones
20-Turquoise
(To:DaveClark)
You could do this with weblink or jlink. Display a webpage form for the user to select from and then
weblink could change both the model material and the material parameter. Or jlink/weblink could read
the value of the material parameter and set the model material accordingly. Or you could have a
jlink parameter editor. Check out the sample jlink programs under
PRO_INSTALL_DIR/jlink/jlink_appls/jlink_param
