parameters in Part list
gcontreras
Hi!
All of the parts from my assembly have some parameters which I added. I need to add a table in the drawing of the assembly with the list of parts of the assembly which include for each part the parameters I made.
I researched a lot in internet and found what I needed, which was to add with tools from the tree all the parameters wanted in the tree of the assembly. and then at the drawing I should click in "Table from file" and then I should look in a folder from "library" a file called "struktursrk_a4q_alles.tbl" (This is the file for Creo in German). My problem is that I don´t have this files at my computer or any other related.
Could I download somehow this file? Or is there another way to make this list with paramters?
Thanks so much
Best regards,
Edna
2 REPLIES 2
I don't think that this method will not be tied back to the parts in the assembly and therefore won't update when the parameters change. I don't have time to write up a detailed explanation, but I'd suggest you research "repeat region" tables. These can pull parameter (and other) information from part parameters dynamically.
LinkedIn
Garcia,
use Creo HelpCenter to learn Repeat Region functionality.
http://help.ptc.com
Martin Hanak
Martin Hanák
