pen_2 (yellow colour) for dimension lines, letter and section lines
routhusrinivas
I have problem printing pro/e drawings to PDF(monochrome)
im using pen_2 (yellow colour) for dimension lines, letter and section lines. While printing PDF (monochrome) i have to show dimension line and letter with different thickness.
If we edit pen_2_weight value from default 1 to 1.75 the size of lettering is enlaging to undesirable size but the dimension line thikcness is ok as per our standards. (these both must be in yellow colour (which is controlled by Pen_2_line_Weight)).
I also tried with table.pnt but iam unable to satisify the condition of the dimension lines and lettering font sizes.
And iam not sure whether plotter congfiguration file will help me.If it does please breify me the procedure.
Please help me how to solve the problem.
Thank you in advance
Srinivas.Routhu
In your Drawing Options file set
LINE_STYLE_STANDARD to std_iso
this allows you to have different text and leader line styles
Have a look here http://communities.ptc.com/message/155650#155650
