I would like to know what need to be done in order to have precision as 2 for newly added parameter into drawing file.
Thanks and Regards
Ketan
You may also want to read these discussions:
Ketan
I am not sure you can actually control the precision of a parameter, but you can control the number of decimal places displayed in a note or table by adding [.2] in the note.
some note whatever &some_parameter[.2]
Dave
Parameter Decimal Place thread provided required solution... Thank you every one for addressing my issue.
drawing option > dual_digits_diff > -2
good luck!
