"Please confirm resetting Family Table values for given Instance to their previous values."
rcardi
3-Newcomer
Someone can explain exactly when this issue appends?
What the reasons are? Which actions causes this error?
I think it can appens when different versions of family table components are in local folder and library folder...
Thanks...
2 REPLIES 2
We get this same error once in a while, cannot figure out why.  It eventually goes away.
Here is some information I found in article CS168523.  If you can't access the article, the pertinent information is as follows:
Title:
Message Please confirm resetting Family Table values for given Instance to their previous values while opening an assembly in Creo Parametric 2.0
Cause:
  • Corrupted dimension for a component placement.
  • Message logs show:
    • Invalid value: # of dimension d# (feature id #, model xxx)
    • Regeneration has been interrupted due to errors
Resolution:
  • Edit Definition of component xxx:
    • Either modify above dimension if present
    • Or just validate if properly constrained
  • Regenerate and Save the assembly
Please give this a try to see if it helps.
Another case I found in the database required the models to be sent to Tech Support, so that they could be fixed by R&D.
Amit
