"Save new files to model's CAD document"
kwsauter
When I do 'save a copy' to pdf, I get a checkbox that says "Save new
files to model's CAD document" that is automatically checked. I see no
useful purpose for this. I can't find the document after I save it if I
check it. Does anyone use this, and if so, what for?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
214-860-6826
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
Ken,
this functionality will add the PDF as an attachment to the original CAD
model. The idea is to link the derived copy to the original CAD model for
traceablity in Windchill.
There is a property/preference that will render the attachment
"out-of-sync" when the CAD model is iterated, which I have forgotten.
Maybe some one can chime in on that?
/Bjarne
"Sauter, Kenneth W (SA-1)" <->
15-03-2010 20:28
Please respond to
To
cc
Subject
[proecad] - "Save new files to model's CAD document"
When I do 'save a copy' to pdf, I get a checkbox that says "Save new files
to model's CAD document" that is automatically checked. I see no useful
purpose for this. I can't find the document after I save it if I check
Ken Sauter
PO Box 740188
Dallas, TX 75374
214-860-6826
NOTICE: This e-mail transmission (and/or the attachments accompanying it)
prohibited. Any unauthorized interception of this transmission is illegal
under the law. If you have received this transmission in error, please
promptly notify the sender by reply e-mail, and then destroy all copies of
the transmission.
"This (document/presentation) may contain technical data as defined in the
International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of
this material is restricted by the Arms Export Control Act (22 U.S.C. 2751
et seq.) and may not be exported to foreign persons without prior written
Site Links: View post online View mailing list online Send new post
via email Manage your subscription Use of this email content is
governed by the terms of service at:
Thanks to everyone for the replies. My original question was:
The replies follow
They become "attachments" in the Windchill CAD Document record. To
retrieve the .PDF, you have to go to the "attachments" section of the
Windchill CAD Document record. To remove the .PDF, you have to use "edit
attachments".
Here's a way to turn off the check box.
I presume you are using Windchill. The file is saved as an attachment
to the CAD file in Windchill. There is a config.pro option to have the
box unchecked by default:
dm_save_as_attachment no
When you check the file in it shows up in PDMLink on the details page
