My company wants to introduce standard bomballoons values for fasteners.
e.g. A hex_nut_m6 is always number 301.
Now I want to make a repeat region that reads the rpt.index value for all components, but if a component has a parameter called pos_nr, it should obtain that value.
See screenshot, modified in Paint….
I assume this should be possible with relations in repeat regions but I cannot get it to work.
Anybody out there who can help me?
use repeat region relation:
if exists("asm_mbr_POS_NR")
myindex = asm_mbr_POS_NR
else
myindex = rpt_index
endif
Repeat region cell contents:
&rpt.rel.myindex
MH
Try:
if string_length(asm_mbr_name)>9
if extract(asm_mbr_name,1,10) == "hex_nut_m6"
Myindex = "301"
else
Myindex = rpt_index
endif
else
Myindex = rpt_index
endif
Then in your repeat region instead of this:
&rpt.index
You will need this:
&rpt.rel.MyIndex
Looks like I may have missed the second part of the question in regards to pos_nr.
Try:
if string_length(asm_mbr_name)>9 & exists("asm_mbr_pos_nr")
Myindex = "301"
else
Myindex = rpt_index
endif
else
Myindex = rpt_index
endif
&rpt.index
You will need this:
&rpt.rel.MyIndex
Are you putting the parameter 'pos_nr' in all of your standard hardware item parts?
Does 'pos_nr' change with the part? Hex_nut_m6 is 301, hex_nut_m8 is 302, hex_bolt_m6x35 is 303, etc.
Do you hardware items have unique part numbers?
Not sure what the length of the asm_mbr_name has to do with anything. Too general of a variable to be useful.
string_length(asm_mbr_name)>9 is a validation check. Without this check if the extract function tries to extract for a component that has less than the number of character you are trying to extract then it will return a NULL. The NULL doesn't report as NULL though it comes back as a blank for that and everything after it which leads the user confused as to what is going on.
I made the assumption that the part file name is hex_nut_m6. If that is not the case then Ruben can obviously adjust as needed.
else
myindex = rpt_index
endif
&rpt.rel.myindex
MH
Do you have any insight on what might prevent this relation from working. I added the following relation:
IF EXISTS ("asm_mbr_item_number")
table_item = asm_mbr_item_number
ELSE
table_item = rpt_index
ENDIF
And I reported &rpt.rel.table_item in the table column.
But the repeat region did not substitute the assembly member ITEM_NUMBER parameter for rpt_index.
I then tried adding the parameter ASM_MBR_ITEM_NUMBER in the local parameters below the relations but this resulted in all the table items reflecting the last assigned ITEM_NUMBER parameter. In other words - The first item was 305, the next item was 304, the 3rd item was 303 (as assigned by ITEM_NUMBER) then all subsequent items were also 303 instead of resuming with 1 and automatically indexing from there.
