regen preview - creo2
BobFrindt
2-Explorer
Using Creo2.
When a dimension is changed, Creo does a preliminary regen for that dimension change. If the model is large this can take 20-30 seconds. If a change requires modifying half a dozen dimensions, then there is a 20-30 second lag between each dimension that is changed and then ultimately a regen of the entire model once I am finished.
I would much rather change all of the dimensions first and then regen everything at once.(one regen per change vs. half a dozen)
Does anyone know ifthere is a setting that will allow this preview to be turned off for larger models?
TIA
enable_auto_regen no
/Bjarne
