Is it possible to make a relation between a parametric and a Excel-table.
For example a block with (LxBxH) and if i chance the lengthzell in Excel, it should also change in Creo.
But not with "Excel Analysis" because in this feature I can only set 1 relation.
Please help me!![]()
No, not out of the box. You will need a custom application. Either something you write yourself in J-Link or VB or use a commercial utility like Nitro-CELL.
Thanks for the fast answer,
But is there no chance to make an individual Iporttable for a parametric part?
Do you know which custom application is usable for this?
