remove part of the thickness of a wall in sheet metal
DennisRehmer
To all,
I have a situation where I have a sheet metal part with two 90 degree bends (approx. .31 thick and .625 wide 1 inch to the bend radii) and I need to have "machined" off a small section (.063 deep) across the width removed. So there would be about a 1 inch x .625 inch area that would be .063 thinner than the rest of the part.
I have tried several different types of walls and extrusions, and nothing will allow me to do this. I cannot convert the part to solid, as I have flat patterns in a family table that I am using on a drawing.
Any help on this will be greatly appreciated. the strange thing is if i add a hole, it allows me to pick a depth for the hole and it works.
Dennis J Rehmer
BenLoosli
(To:DennisRehmer)
Put the bent part in an assembly and then do an assembly cut to remove the material.
StephenW
(To:DennisRehmer)
Using extrude, turn off the "remove material normal to surface" toggle.
psobejko
(To:DennisRehmer)
Are you talking about a situation like this:
if so, extruded-cut with blind-depth will only work if you toggle off the circled "Remove Material normal to surface" option...
