I would like to add a few blank cells to a repeat region I have (NOT a header or footer) but in between values. it is a hose assembly and I am adding attributes from the hose ends.
Our current format has two tables seperated completely and we manually type in values.
I would like to keep the same look but it seems at the very least they will have to be in the same table. but in order to make it look the same I need to add blank spaces between cells.
Ideally I would like to have 2 tables calling parameters from the hose ends
Can this be done by writing a relation or by another way?
Just off-hand: have you considered using bulk items? Could you post an image of what you're looking for?
