We have made some changes to the Restricted_Parameter file and restarted Creo. It reads the new file but when we go to update the restricted list, Creo says the list is already up to date and no update is done. Has anyone else experienced this bug?
I did a search of the knowledgebase and found this CS article, but it says no plans to fix in Creo 7, 8 or 9.
We are on Creo 7.0.10.0.
I found the issue.
IT changed the drive mapping and so the file was not being loaded. Changed the config.pro to point to the right file location and all is good now.
I think I've run into this a few times in the past. Have you tried deleting and recreating the parameter? I know it's not an ideal option but I've had success with it. You could also try setting a new value for the parameter before updating the restriction definition.
I found the issue.
Oh, those IT folks. I had a memorable day (which turned into a week) some years back where they renamed our server and didn't tell anyone. It was a delightful cornucopia of troubles. What fun.
