sava as name(pdmrev).pdf
dzanella
Hi gurus,
sorry for the intrusion,
I have already post this in the CAD area without success,
( and having a lot of request on how I did it. )
I need a procedure to export from a drawing,
A dwg and and a pdf file, with the format :
Name_revision.pdf
Name_revision.dwg
Where revision is the value of PDMREV
( 0 - 0a - 0b - 1 - 1a.etc )
Is it possible do that via macro ?
Do someone of you have already faced it ?
Thanks in advance
_____
avast! Antivirus <">http://www.avast.com> : Outbound message clean.
Virus Database (VPS): 090507-0, 07/05/2009
Tested on: 08/05/2009 20.57.54
avast! - copyright (c) 1988-2009 ALWIL Software.
FV
(To:dzanella)
Hi all,
Daniele,
You could combine pdf or dwgoutput mapkey with parameter info mapkey and with 'OS Command' based mapkey. If you are outputing pdf file to the current working directoryyourOS script has to look for the latest modified file with the known extension (pdf for example). Yourparameter info mapkey would output file parameter.infto the current working directory -grep your parameter value out of it with our OS script and then rename pdf or dwg file with os command.
HIH.
Feliks.
In Reply to Daniele Zanella:
Hi gurus,
Name_revision.pdf
Name_revision.dwg
Thanks in advance
_____
avast! Antivirus <http://www.avast.com> : Outbound message clean.
