scale labels in drawing view
ChristianSmith
In drawing mode in Wildfire 5.0 is there a way to make the scale that appears under a vew a fraction instead of a decimal? What about the format?
This is controlled by a config.dtl setting called view_scale_format - options are: decimal, fractional & ratio_colon
There is another setting to look at which is view_scale_denominator which controls the denominator in the scale fraction.
Hope this helps!
-Greg
Hope this helps!
-Greg
