Is there some possibility to search for part in assembly according model parameter?
thanks for help in advance
T.
Is that because the parameter is not a String? Is the parameter a Real or an Integer? Then the Type should be changed to match.
If the search tool wasn't so cryptic, I would say search tool...
I thing the correct answer -is- search tool...
But don't ask me how to use it for your use case.
I wish I had an intro to using rules for this. I don't see that it can't work.
I've attached a rules schematic, though PTC probably rearranged some of it for Creo.
I think you want to Look for - Component and search for the Attribute where the parameter = the desired value. Since it's an assembly I suspect Look In will also come into play.
Try this settings:
Jose
Hello Jose,
I have tried to search accordin to your settings and it seems it does not work.
B.R.
T.
Thank you David - it was an integer... T.
Jose should get the credit, I just pointed out the equivalent of a typo.
