Right now I am working on an assembly with multiple parts with similar geometry. I wanted to know if there is a way for me to select all geometry with the same dimensions/features? Attached below is a reference, where I want to select all roller geometries without having to individually select them.
Thank you.
If these components all have a common parameter or name, then you can use the find tool to collect all of them with a search query.
Thank you! Understood
