I hope i can explain it well that everbody is unterstanding my problem.
So when i used Creo Parametric 1.0 it was a default setting or just normal when i was drawing a circle in a sketch that it automatically shows while going from small to big with the circle with the mouse to type already the dimension i want.
Now on 6.0 i have to click on the circle symbol place it on the layer and then i can change it?
Is it somehow possible to change that f.e. with a config setting or do i have to accept it and live with that.
I think this is duplicate post of https://community.ptc.com/t5/Part-Modeling/Adding-dimension-while-drawing/m-p/618837#M32462
Hello everyone,
Since the thread linked about has an accepted solution, I will go ahead and close this duplicate.
PTCModerator
