setting piping precut lengths to 1" incerments
jgronwick
3-Newcomer
Is there a way to set the precut lengths to 1" increments in a piping line stock file?
6 REPLIES 6
StephenW
(To:jgronwick)
I don't remember any options for setting precut lengths.
Are you talking about when you report this information on a drawing? If so, you can simply add the [.0] to the end of the reporting parameter so it rounds to zero decimal places.  Probably not really what you are asking, but thought I would throw it out there anyways.
Thanks for the reply.
I am looking for predetermined length increments that piping will take into account when routing the design. Similar to the acceptable bend radii and angle.
Kevin
(To:jgronwick)
Not sure if these will help but there are parameters for Spec Driven and Non-Spec Driven design that set the minimum and maximum segment lengths.
Non-Spec Parameters:
MIN_STRAIGHT_LENGTH
MAX_OVERALL_LENGTH
Spec Parameters (dialog box):
Max Overall Length
Max Segment Length
Min Segment Length
jgronwick
3-Newcomer
(To:Kevin)
No, but thanks. I'm looking to set line stock in 1" increments.
I think that I will need to set decimals to zero and ceil the pre cut value in the relation of the solid part. I was trying incorporate that in the design of the pipe.
Kevin
(To:jgronwick)
While it doesn't specifically set the value it does set a rule to check pipeline segments. Setting both values to 1 will flag segments less than 1 and segments greater than 1 as violating the rule but it's still up to the user to change the segment length to the correct value. Based on what I'm seeing you can't set a relation because the value gets locked by Piping.
jgronwick
3-Newcomer
(To:Kevin)
Correct. I will only use this value of a quantity value for documentation.
