sheet metal half-shear button
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hi ... CREO4 user ..... trying to create a half shear button in sheetmetal part ... what is easiest/best way?
- Labels:
Sheet Metal Design
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
In the sheetmetal, use sketched form, change type to "piercing" instead of "punched" (2nd icon in the ribbon).
Then just sketch a circle...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
BTW ... I tried to do a "sketched form punch" .... it made the small half-punched hole in the front surface, but creates a larger (added sheetmetal thickness) plug diameter on the back surface. Hole diameter in front and plug diameter in back should be the same on a half shear button
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Not sure what you mean by a half-sheer button, but how do you punch material and get the same diameter on both sides of your sheet? The material has to be deformed someplace and I would expect the back side to be larger than the punch by the material thickness.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
A half-shear button is a common sheet metal practice used for accurately locating parts prior to spot welding ….. it basically punches a hole at half-depth on the front surface while creating a plug, of same diameter, at half depth out from the backside surface.
I’ve been able in the past to create this on solidworks sheet metal parts with just a two step process …. 1) create a hole at half depth on the front 2) create an extrusion out the back ……………. But I can’t seem to do it in CREO
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Check the sample files at below link, I hope it will help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
hello, thank you for your reply, but for some reason it won't let me access that link …. says "I don't have permission to view that directory" …. ???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
No ….. this is what a half-shear button is ….
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I think you can use punch tool half-shear button creation .... if it matches your requirement...
files from earlier document are attached here...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Perfect …. thank you very much !!
