Looking for a simple way to model this part. Thin (0.004") sheet metal strip, roughly 1/2" wide, wrapped around 1.5" diameter with ends overlapping 1/8" (so not an exact cylinder). Must be a very common use case. How do people model this?
thanks in advance.
Part attached for reference (which doesn't yet meet the need)..
I don't have a way to open the model, but if this is like a hose clamp strap, then I would do this as a thin extrusion with a sketch of the circle and the formed ends. The thin feature avoids having to deal with the tiny .004 offset in the sketch.
It is exactly like a hose clamp strap - thank you - was trying to think of a similar common item. There must be thousands of models like this - but so far I haven't found a good, simple way to address. Note: The part that we're dealing with has a bunch of features (edge profile plus cuts) that need to be addressed in the flat pattern, then formed (rolled with overlap) and spot welded.
I would not expect a lot of faithful models. Even the mass produced straps are rarely round, instead conforming only on installation. It doesn't seem to me that many need a detailed model and instead opt for a decent place-holder.
Do I correctly detect some form of cost reduction?
