summary - Export to DWG - ACAD14 - Wildfire5-M020 - "DWG file creation failed."
DiVenti
Summary:
Drawings previously created in WF3 and opened in WF5 containing BOM
balloons could not be saved as AutoCAD14, DWG file format.
Resolution:
Clean region, recreate BOM balloons and the save/export to AutoCAD14 goes
fine.
Hope it helps.
Luke
Luke Diventi <->
03/25/2010 12:59 PM
Please respond to
Luke Diventi <->
To
cc
Subject
[proecad] - Export to DWG - ACAD14 - Wildfire5-M020 - "DWG file creation
failed."
Hello Pro/Users,
Before placing a call with PTC support I want to see maybe I can get my
fix from this great forum.
Problem:
When Pro/E drawing is saved or exported as a DWG file in AutoCAD14 the
save operation does not succeed and an error message appears.
We noticed that this happens when the drawing contains BOM balloons.
Error Message:
Temporary solution:
We save in Autocad2000 and the export is successful.
Permanent fix (we really need the AutoCAD14 format since a lot of our
vendors are requiring it):
Any thoughts, fixes?
Thank you in advance!
3 REPLIES 3
AutoCad 14 was issued in 1997
how many more years till will every cad software program is not required to export in AutoCad 14 format
DiVenti
(To:DiVenti)
I know, I know, I'm having the same discussion without success over and
over...
I'm assuming this happens because small fabricators/manufacturers which
cannot afford an AutoCAD 2000/2007/2010 license...
So our standard save is Autocad14.
dave mcclinton <->
03/26/2010 03:07 PM
Please respond to
dave mcclinton <->
To
cc
Subject
[proecad] - RE: summary - Export to DWG - ACAD14 - Wildfire5-M020 - "DWG
As it happens, I just had an issue today where a machine shop needed a
file in DXF for autocad ver 12(!) for the conversational control on
their wire EDM machine.
Their complaint was that the 2D spline curve I sent them was coming in
as polylines. I explained that v12 DXF will always do this...
You may find this as well. Many machines with 'Windows' interfaces are
being used now. We have a machine that still uses NT!
Christopher Gosnell
TRIGON INC.
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
