We recently completed an upgrade from Creo 6 to Creo 10.
One of the items I failed to test/verify was our custom symbols. After all, decades of using .sym files for symbols and all that.
Now I can't see any of the .sym files.
Drag and drop doesn't work (not a recognized file type).
I can open the 'Define Symbols' menu through the annotate tab and I can edit symbols through what looks like the old interface. Saving them just iterates the .sym file and still doesn't allow me to use them on drawings.
I've been searching, and will continue to search, for instructions on what to do. I'm just sure PTC would have had the foresight to provide with this change. /s
What am I missing? Anyone have a quick link or easy fix for my predicament? Was it some config I scrubbed out during the upgrade?
Browsing for symbols in the pro_symbol_dir still works for me in Creo Parametric 10.0.2.0:
Annotate (tab) > Annotations (group) > Symbol > Symbols (menu) > Browse Symbols:
Do you have pro_symbol_dir set to the folder where your symbols are?
Yes, I have pro_symbol_dir set.
I can also navigate to that folder and the .sym files don't show up. The filter only allows .drw files.
Sounds like you are looking for a symbol pallet which is a drawing file. Starting with Creo 8 the symbol interface changed. The user symbols are now graphically displayed rather than in a folder.
I just started testing how to create my own symbol pallet .drw.
What a pain.
Thanks for the link. Once I find some free time to verify this is the only path forward I'll come back and report if yours is the only solution.
You're my hero.
I simply overlooked that drop-down.
