Dear All
I'm looking for a method to make two parts move symmetrically . I know it's possible to do it in SOLIDWORKS but I don't find the way to do it with CREO.
Many thanks for your help
O.Pavot
you can define relation on assembly level. I attached Creo 7 example.
There are at least three ways to solve your problem.
Define relations as MartinHanak wrote
Define component placement as constraints (see the attached picture)
Define component placement as connections, Then create two servo-motors in mechanism and run them together
Hi @opavot1 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
