thread hole
Bryszard
8-Gravel
thread hole
Hello, I'm using parametric creo 2.0. I want to make a thread hole in my part. I need to make an M36 x 1 thread, but I can't standard creo because it's a m36 x 4 choice.
is it possible to add a new thread hole to the drop-down list?
Chris3
(To:Bryszard)
2 REPLIES 2
Chris3
(To:Bryszard)
You can modify the .hol files to include a M36x1 option. Information is below:
https://www.ptc.com/en/support/article/cs31227
https://community.ptc.com/t5/Creo-Modeling-Questions/Standard-hole-files/td-p/278260
If you don't have access to edit the hole files, you can create a simple hole and then add a cosmetic thread. You can then create a manual note on your drawing with a leader note. This method is a little crude but works.
Here's a youtube video as well:
https://www.youtube.com/watch?v=wqUSN0Ps3BU
This Creo Parametric tutorial video shows you how to create Cosmetic Threads in a model as opposed to using Helical Sweeps, which can be significantly detrimental to your regeneration time with little benefit. This video covers: Simple and Standard Threads Cylindrical and Conical Threads Feature ...
