tiff image from WF4.0
DennisRehmer
To all,
In WF4.0, you can directly make a pdf file of a drawing. Is there a way to make a tiff file, other than to pop the window, in WF4.0 so you get an output similar to a pdf?
Dennis
4 REPLIES 4
Dennis,
try something similar to ... File > Print , i dialog window expand list of printers/plotters and select TIFF located at the end of the list.
Martin Hanak
Martin Hanák
Martin,
Thanks for the suggestion. I will try this to see if it gets me what I need.
Dennis
Hi, Dennis.
Have you got what you need, I have another problem here. I want to use some Tiff files. But I only have PDF formats. Compared with making Tiff files directly using some Tiff creators, is that converting PDF to Tiff files with the help of PDF converter much more convenient? I am totally a green hand on this field. Any suggestion will be appreciated. Thanks in advance.
Best regards,
Arron
Arron,
My issue of needing tiff files, sort of went away. The person looking for this decided just to use PDF formatted files.
Not sure what the most convenient way is to get the tiff. I am wondering if if Creo it has the optioni for both tiff and pdf, I am not sure.
Sorry I could not be more helpful on this.
Dennis
