Suppose you have the following scenario.....
You have a rectangle with one side dimensioned L1 and the other side
dimensioned L2.
There are three versions of the part created using a family table.
You need to add a tolerance to both dimensions.
For -01 your need a tolerance of +0 -3.2 for L1 and +0 -6.4 for L2.
For -02 and -03 both have a tolerance 0f +0 -3.2 for both L1 and L2.
How do you do this so it shows up correctly on the drawing?
