unable to edit dimensions in sketcher mode - student license
PK_10540520
2-Explorer
Hi All,
I have a student license and from past 2 days i get the below error in sketcher mode when i try to update the dimensions. It doesn't allow to modify any of the dimensions in sketcher mode.
"When a constraint is active, right click to cycle through lock/disable/enable the constraint. Use Tab key to toggle active constraint. Press and hold Shift to disable snapping to new constraints."
Kindly support as i am unable to work.
Thank you.
did you ask another student?
Martin Hanák
StephenW
(To:PK_10540520)
@PK_10540520
I'm not sure if this is your problem specifcally, but the issue seems to have come up a lot
https://community.ptc.com/t5/3D-Part-Assembly-Design/Can-t-enter-dimensional-value-after-double-click-in-model-sketch/m-p/857392
Hello @PK_10540520,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
