hello everyone, could you explain this update of the offset and project commands
In my humble opinion it seems to have gotten worse.
Now I have to confirm the command and before I didn't need to
there has been some discussion this in these posts:
maybe they will help
You are not the only user to experience disappointment with this enhancement. If you find issues not covered by the threads posted by @StephenW , please document them. Post them here and open a call with PTC support. @mneumueller at PTC has been following up on this issue when use cases are clearly documented.
I would think it worthwhile for PTC to map the pre-enhancement selection workflows to the new command and publish that as part of the help files. @mneumueller has been responding to issues in this forum which is great. The convoluted nature of this topic suggests that a quick reference card style document is needed to convey the workflows for different use cases.
Seems to be a common opinion!
