Is it possible to make a variable chamfer (as variable round) in creo2 ?
In set option, I have on line # 1 : with size of chamfer.
Is it possible to choose an edge and set chamfer size to 5 on one extremity and 10 on the other, for example ?
Insert a -round- feature to your liking and use the edges of the new -round- feature to -sweep- a chamfer-like fill (internal)/cut(external).
try applying variable section sweep feature.
😄 this is clever!
thanks!
Libor
(btw, i made it differently - variable round and then boundary blend)
