I'm trying to change the format of a drawing and am running into a problem.
Pro is moving the projection and auxilary view lines around. It is also
collapsing the arrowheads to the view line. The new format is smaller than
the old format (11 X 17 vs. 11 X 44) however the view fits. The problem is
that I need to do this on an ongoing basis to create Notice of Change
(NOC)drawings . The idea was to duplicate the original drawing and change
theformat to create the NOC version. I created and tested a new format (11 X
43) and it moves the lines a little, so it does seem to be due to the format
size change. I don't want to have to go in and manually change the views
every time. Is there anyway to workaround this?
David W. Lawrence
BAE SYSTEMS
Mechanical Systems Integration/COA
Voice (301) 231-2924
Fax (301) 231-3397
