Hi
I have a question, when you are into asm and you want open a drw of part you can with the macro or not? because if I try to open a drw of prt not open a prt but open the drw of asm
Thank You
This is a common question. One of these will help you:
https://community.ptc.com/t5/Modeling/Open-Drawing-From-Model-structure/td-p/753908
https://community.ptc.com/t5/3D-Part-Assembly-Design/Quick-open-drawing-from-part/td-p/928587
https://community.ptc.com/t5/System-Administration/Mapkey-Writing-Editing-Tips/m-p/604214#M24810
https://community.ptc.com/t5/video/gallerypage/video-id/6201022425001
step no. 1 ... select part in Model tree, RMB and open part in separate window
step no. 2 ... open part drawing using mapkey
Hello @Daniel82,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
