Is there a way to automagically add a parameter when exporting a ProductView file from Pro/E (WF5)? I've looked through the recipe editor, but have had no luck. Ideally, I would like that parameter to have a string valuethat is alreadypopulated.
Thanks!
Joshua Houser
(have I talked to you about FIRST robotics yet?)
Pelco by Schneider Electric
MCAD Range Technical Officer
