CL command, menu drill cycles
cncwhiz
I have a trajectory sequence that I want to put some drill cycles in. I have tried "inserting" the cycles but they did not work the way I wanted. I know that in the "cl command" one of the picks is "cycles". Can someone point me to what all the picks to define the drill are. I know the syntax in the cl file but what do they represent?
0 REPLIES 0
