Creo Parametric 2.0 and 3D Connexions Space Pilot Pro
ChrisCollinson
6-Contributor
Hi All
Anyone got the 3D Space Pilot Pro working with Creo 2.0, if so what drivers did you install to get the interaction with Creo 2.0
We have just upgraded and cannot find any drivers to add the menus to Creo 2.0 and program the device
The model control functionality works ok but we cannot get any of the software to register with Creo 2.0
Thanks in advance
1 REPLY 1
That's the same for WF5. After disabling the undo/redo function in ProE, you can program your space pilot. At least, in WF5.
Met vriendelijke groeten, Best Regards,
Hugo.
