Decimal places being output in Customize
JeffVoegele
Hi again,
If you use an &string to fill in a value in the customize dialog box, the value comes out with 6 decimal places. Ie. if I use &pocket_number for the tool number, I get 131.000000. How do I remove/control the decimal places?
Jeff Voegele
Solar Turbines
Hi Jeff,
When using parameters in tables you add in square brackets the decimal and the number of places you want.
&mfg.oper.workcell.head.tooltbl.cutter_diam[.2]
Cheers,
Dino
>>> <-> 7/7/2005 3:09 PM >>>
Hi again,
Jeff Voegele
Solar Turbines
