Force Creo to open drawing on sheet #1 ?
Level 11
Is there a way to force Creo to open a drawing with sheet #1 as the active sheet? Currently whatever sheet was active with you last saved the file is the sheet it will open up first.
I have a need to force it to open up sheet 1 regardless of how the user last saved the file.
Any ideas?
Re: Force Creo to open drawing on sheet #1 ?
There is a product Idea (enhancement request) to do this but I don't think it is directly available.
https://community.ptc.com/t5/Creo-Ideas/Default-opening-multi-sheet-drawing-on-first-sheet-Sheet-1/i...
You may be able to use Drawing Reps to do this but not in any automatic fashion without some sort of customization.
Level 12
Like Stephen says you could do it with customization. One possible way would be to write a jlink (or use some other api) listener that would listen for a OnAfterModelRetrieve action and if a drawing then use SetCurrentSheetNumber(1) .
__________________________ Creo 5.0 Sneak Peek Creo 5.0 is scheduled for release in March 2018, but we’re giving an early opportunity for Creo users who don’t want to wait! In the Creo 5.0 Sneak Peek you’ll be able to test enhancements before the official release.
Fill out the Creo 5.0 Sneak Peek Sign Up Form For questions, please reach to SneakPeek@ptc.com
