How to calculate stress in a specific point?
dpettersson
I have done a static analysis on a beam and I want to calculate the stress at a specific point. How do i do that? I have tried using the dynamic query but I cant pick out the exact point as I want to.
Sketch a curve, with one end at the point that you want to measure, and rerun the analysis. Then you can show a graph of the stress along that curve. It will give you the choice of which end to make "0". Make sure you look at the correct end of the graph.
Thank you very much!
